Budget power supply for a budget build in india
Sep 17, 2018
5
Hi guys i trying to build a budget gaming pc
My config is:
Ryzen 3 1300x
Ddr4 8gb ram
Asus a320m k prime mobo
Gtx 750ti
Which power supply should i buy
Iam trying between corsair vs450 antec bp450s and cooler master mwe450 pls suggest me a good psu and i will upgrade it to something like gtx 960 or gtx 770 so suggest me a psu under 2500 and a motherboard for 4500rs
bignastyid
MERGED QUESTION
Question from shuyaib007 : "Budget power supply for a budget build in india"
Vic 40
Herald
For psu would i probably use this,
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16817438145
don't know too much about it,but has enough power and then some left which keeps loads low so temps stay probably low as well which is better for components,also from a mostly reputable brand.
For motherboard either one of these,
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16813157763
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16813157843
yes i know second above budget,but with four ramslots and latest chipset probably worth it.
niravshah
6
well for 2500 INR corsair VS 450 or Antec 450 is way to go. you can get one of these around 2300 INR from mdcomputers or try find a good deal in local store.
for motherborad i would say if you haven't bought A320 yet then starch up you budget little bit and get a B450/B350 which will cost you bit more but gives you 2 extra ram slots and of course overclocking ability.
