Build Advice Build advice please
Dec 29, 2023
Hello, gods of hardware. My old study laptop is throttling up to 95-100 degrees when launching Minesweeper, so I decided to join the pcmasterrace for a while.
I'm trying to put together something that will hold the fort for another 4-5 years, but we'll see. So far, I've gathered this parts list: https://pcpartpicker.com/list/J4JYfy
The case should be big enough, I think, and if I understand correctly, the PSU should have a direct 12-pin connection with the GPU without any adapters. I don't know much about MOBOs, but the ARM5 with wifi seems to be compatible with everything, though I might need to update the BIOS for the CPU to work.
Well, before buying such a beast, I got a bit paranoid about whether I might have made some mistakes. After all, I haven't built my own PC before, so if someone with more experience could take a look, I would be very grateful.
P.S. Extra info - I plan to play at 1440p-144fps+. I play almost everything, mostly online games, MMOs, ARPGs (PoE), competitive, story games (Cyber2077), Tarkov, etc. And I'll use it for work (programming) too, but I think this beast will handle it.
Reactions: Why_Me
Well, with a 4090, you won't have to worry about upgrades for awhile, on a 1440p system. Made a few changes, mostly to get you more storage. Games are just getting bigger these days. Also changed the board to an x670 board.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($383.00 @ Amazon)
CPU Cooler: Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler ($55.98 @ Newegg)
Motherboard: Gigabyte X670 AORUS ELITE AX (rev. 1.0) ATX AM5 Motherboard ($249.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($104.99 @ Amazon)
Storage: TEAMGROUP MP44 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($111.99 @ Amazon)
Storage: TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($256.60 @ Amazon)
Video Card: Gigabyte GAMING OC GeForce RTX 4090 24 GB Video Card ($2029.90 @ Amazon)
Case: Lian Li LANCOOL III ATX Mid Tower Case ($144.99 @ Newegg Sellers)
Power Supply: Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($159.99 @ Newegg)
Monitor: LG 32GP750-B 31.5" 2560 x 1440 165 Hz Monitor ($279.00 @ Amazon)
Total: $3776.43
Generated by PCPartPicker 2023-12-29 10:17 EST-0500
Reactions: friezy
Tweaked the build a bit:
I am guessing a mix of Amazon and newegg shouldn't be a problem?
Modern looking air cooler with minimalistic RGB and digital temp readout
mobo with pcie 5.0 ssd support for future upgrades
fastest pcie 4.0 ssd available today
Case with front panel type C and minimalistic ARGB
ATX 3.0 Tier A PSU with 10 year warranty
32" QD led 600 nits 2k screen. 2k res for a 27" is a bit meh
CPU Cooler: Deepcool AK620 DIGITAL 68.99 CFM CPU Cooler ($79.98 @ Amazon)
Motherboard: ASRock B650E PG RIPTIDE WIFI ATX AM5 Motherboard ($189.99 @ Newegg)
Memory: Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory ($92.99 @ Amazon)
Storage: Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($119.99 @ Amazon)
Case: Phanteks ECLIPSE G500A DRGB (Fanless) ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: Deepcool PQ1000M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($124.99 @ Newegg)
Case Fan: ARCTIC P14 72.8 CFM 140 mm Fans 5-Pack ($34.09 @ Amazon)
Monitor: MSI Optix MPG321QRF-QD 32.0" 2560 x 1440 175 Hz Monitor ($374.61 @ Amazon)
Total: $3509.53
Generated by PCPartPicker 2023-12-29 10:28 EST-0500
Reactions: friezy
You want low profile RAM so that it doesn't impede that dual tower cpu cooler. btw here's a case that's easy to work.
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler ($63.99 @ Amazon)
Motherboard: *MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard ($217.99 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($104.99 @ Amazon)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($119.99 @ Amazon)
Video Card: Asus TUF GAMING OC GeForce RTX 4090 24 GB Video Card ($2159.98 @ Amazon)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case ($96.99 @ Adorama)
Power Supply: MSI A1000G PCIE5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($169.99 @ Amazon)
Monitor: LG 27GP850-B 27.0" 2560 x 1440 165 Hz Monitor ($312.55 @ Amazon)
Total: $3629.47
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-12-29 10:43 EST-0500
A better look at that RAM and case.
https://www.gskill.com/product/165/396/1673491242/F5-6000J3038F16GX2-FX5
https://lian-li.com/product/lancool-216/
View: https://www.youtube.com/watch?v=ykbhuv6yLBc
Reactions: friezy
