Hi and thank you in advance,
I have put together a new work machine with a £1500 budget (+£100 if needed) - There is scope to push this further in a few months for upgrades, but I'm looking for a nice foundation just now. I would like to put in the orders in the next few days, but advice is worth more:
https://uk.pcpartpicker.com/user/eayajb/saved/gKj3Hx
I will sort out the case and OS later.
It will mainly be used for Unity Game Dev. - lighting, animation, rendering (little bit heavy) - mostly coding and building versions with Machine Learning (cores and threads). I would really appreciate a sanity check on my thought process:
* Ryzen over Intel (13/14 gen) balance of cores and power - x3d is overkill / underused here
* Strong motherboard for PCIe Gen 5 graphics (too ££?) focus on not throttling PCIe lanes for future upgrades (PCIe / NVME) lane sharing
- x870Gigabyte Aorus Elite / x870 AsRock Steel Legend - both throttle main x16 lane for additional NVME and PCIe slots
- MSI x870-P Pro / ASUS Prime x870-P - Cheaper alternatives but feel lacking
* RAM can be swapped to 64GB later (Ryzen doesn't support quad very well?)
* RTX 5060Ti 16GB - more than enough for now - CPU and board can support 5080 / 5090 down the line
* Storage - Samsung for OS (DRAM) - WD_Black large files and storage
* AIO cooling would be nice, but already a shade over budget - maybe for another day
My main concern is around the power specs.
* Power - 1000W - Is this a good price point or should I drop to 850W - Thinking about bigger cards in the future
- I'm really not sure about enough cabling / connectors - but I don't really see any need for additional hardware
- "A" rating ATX 3.x on SPL PSU tier list
I'd really appreciate any thoughts or input.
