Build based around i7 and r9 280x
ZapTic
15
Hi, if somebody could finish this PC build i would be very thankful. I have chosen both a very powerful graphics card and processer and would like the rest of the build to not be to expensive because of this.
Rig will be used solely for gaming, streaming, recording and a little editing. If you think i would be better off with an i5 or a different graphics card etc please tell me why and give me advice, i am a noob.
Would prefer to keep the rest of the components around the £400-£500 range.
Prefer Amazon for parts or any UK based websites.
Here are the parts im going to base this build around (unless advised otherwise):
Sapphire R9 280X 3GB Toxic 1100MHz GDDR 5 PCI Express Graphics Card
Intel Core i7 4820K Extreme Quad Core CPU Retail (Socket 2011, 3.70GHz, 10MB, 130W, Unlocked and Unleashed, Hyper-Threading Technology)
Thank-you.
What is your total budget?
Also the new 2011 should arrive on Sept 14.
For now you're better off with a socket 1150 Haswell
Get a R9-290 if you're going to spend that much on a Sapphire R9-280x Toxic
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£236.34 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£25.13 @ CCL Computers)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard (£77.96 @ Scan.co.uk)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory (£52.98 @ Ebuyer)
Storage: Crucial M500 120GB 2.5" Solid State Drive (£52.94 @ Aria PC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£36.00 @ Aria PC)
Video Card: XFX Radeon R9 290 4GB Black Edition Double Dissipation Video Card (£279.59 @ Overclockers.co.uk)
Case: BitFenix Neos Black ATX Mid Tower Case (£26.82 @ Aria PC)
Power Supply: XFX 750W 80+ Bronze Certified ATX Power Supply (£58.99 @ Amazon UK)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive (£9.58 @ Scan.co.uk)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) (£79.98 @ Amazon UK)
Total: £936.31
Generated by PCPartPicker 2014-07-30 23:08 BST+0100
bumping isnt allowed on this forum, :)
anyway, id say look at getting the 4970k instead of the 4820k. there isnt really a good reason to get a socket 2011 machine unless you need 64gb of ram, lots of pci-e lanes, and/or a 6 core i7.
i'll throw a build together in pcpartpicker and see if you like it. im guessing total budget would be around 1000 total?
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard (£124.82 @ Ebuyer)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory (£58.73 @ Ebuyer)
Storage: Crucial MX100 256GB 2.5" Solid State Drive (£79.50 @ Scan.co.uk)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£38.70 @ Aria PC)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card (£283.14 @ Aria PC)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case (£37.44 @ Scan.co.uk)
Power Supply: XFX ProSeries 850W 80+ Gold Certified Fully-Modular ATX Power Supply (£107.83 @ More Computers)
Total: £991.63
Generated by PCPartPicker 2014-07-30 23:03 BST+0100
heres a quick rough draft build. i suggest choosing a case you like, since your the one looking at it, so we can base the build around that. also, fit an r9 290 into the budget as well.
also, if your recording, i suggest getting an nvidia card because it has shadowplay. i suggest this card, about the same as the 290:
http://uk.pcpartpicker.com/part/evga-video-card-02gp42776kr
its a little slower than the 290, but the frame rate drop when recording will be at most a few fps with shadowplay
+1, but what is so good about ShadowPlay? AMD cards also have Mantle so if you want to play Battlefield 4 you will enjoy it.
it depends on the features youd rather have when choosing amd vs nvidia. shadowplay allows you to record without a large drop in fps (which happens while using many other recording programs). its helpful when recording alot of different stuff. also, mantle is very good in the games supporting it, which there arent many. in my opinion i wouldnt use shadowplay, so id go amd at the price point, but its something that the op might find useful
