Hi! Planning to build a PC for my architect friend who is on a 500$ budget. This will be mainly used for softwares such as AutoCad, Sketch Up, Lumion, 3ds max, and some light editing with Premiere and Lightroom. Current build has no GPU which is why we went for the Ryzen 5 2400g due to budget concerns.
Question is: Is the build enough to run most applications smoothly? And more importantly, will 3d rendering be an issue?
CPU AMD - Ryzen 5 2400G 3.6 GHz Quad-Core Processor $158.89 @ OutletPC
Motherboard MSI - B450M MORTAR Micro ATX AM4 Motherboard $69.99 @ Newegg
Memory G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory $164.99 @ Newegg
Storage Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive $45.89 @ OutletPC
Power Supply FSP Group - 550 W 80+ Bronze Certified ATX Power Supply -
CASING Some 32$ local casing 32$
