Build I planned for low cost ( First post )
Jul 14, 2018
This is my first post. I plan build the following PC with limited funds. A friend suggested me this site for reviews/opinions. What are ur thoughts of components and how will they do together:
PC Case: https://www.nzxt.com/products/phantom-410-white
Motherboard: http://www.expertreviews.co.uk/pcs/motherboards/53324/gigabyte-970a-ds3p-review/page/0/1
Processor: AMD Vishera, FX-8370 4.0GHz
RAM : Kingston HX318C10FR/8, HyperX Fury Red 8GB DDR3, 1866MHz
GPU : Radeon HD 7970 / R9 280X (Bus Interface: PCIe 3.0 x16, Max Memory Size: 3072 MB, Core Clock(s): 1000 MHz, Memory Clock(s): 1500 MHz, Graphics API Support: DirectX 11.2/12.0 OpenGL 4.4 Max TDP: 250 W )
What are your intentions of the build?
That processor is almost 8 years old so I'm sure you could find something cheaper.
Also, that is quite an expensive case you should really check eBay as they sell some really nice cases for ridiculously cheap prices
