Build Multi-Monitor Desktop
rishicool2002
7
Hi All,
I've tried to look for this online before posting this here, however couldn't fnd anythign that would fulfill my requirements.
Requirements: A PC that can support 3 Monitors.
Connectivity: 3 HDMI if possible, otherwise, 2 HDMI, 1 DVI. (OnBoard if Possible, else a cheap graphic card)
RAM Support: 16 GB
Processor Support: i3, i5
Form Factor: Doesn't Matter (ATX, Mini-ATX/ITX) Anything will do.
Please let me know if you need more info to help.
Thanks in Advance.
Rishi.
You are too vague!,what would you be doing on those three screens ?,if you are gaming then go for Eyefinity ! even Nvidia has a multi screen platform,Almost any respectable Graphics card today supports output to 3 screens!
I need it as my work requires me to keep eye on multiple things as the same time. This PC will NOT be used for gaming.
I tried looking for Graphic Cards and Motherboards as per my requirements, however either they dont have enough display outputs or have DP ports, which my monitors wont support. I'm trying to minimize the use of converters and would prefer to have direct connection from PC to Monitors.
Hope this clarifies.
Thanks.
Practically, budget is not a problem. However, I'm not planning to invest too much on this system. As I mentioned earlier, to FireMan, this system will not be used for Gaming at all. Its going to be RDP to differnet servers, and monitoing stuff.
If you are still looking for a figure, than I would say anything below $500 would be sufficient. This budget doesn't include the cost of Monitors, Keyboard, etc.
Thanks.
