Hi everyone, I need your help. I want to build my own PC and use it as a "mini-server" for running different Linux VM Machines for tests and educations.
Any advice for motherboard, power supply, ... to install in a Corsair 2000D Airflow?
Approximate Purchase Date: 22.02.2024
Budget Range: approx 500 Euros
System Usage from Most to Least Important: Running Linux virtual machines for educational purposes / Running Trunas CORE/SCALE as a Docker Container
Are you buying a monitor: No
Parts to Upgrade: CPU, mobo, RAM, Storage, Power Supply
Do you need to buy OS: No
Preferred Website(s) for Parts: alternate.de
Parts Preferences: no preferences
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: not relevant
Additional Comments: I will use XCP-NG, if possible quiet components
And Most Importantly, Why Are You Upgrading: no upgrade, I want to build a new PC
Overclocking: No
