Building a comp for someone need help
Espada
363
Hi everyone building a comp for one of my cousins and just wanna make sure that this is all compatible. And if the power supply will be able to handle all this. All he does is torrent, download music, watch movies, surf the web and most intense gaming he says his wife does is the sims 2 which i think wont really need much power to do. So i found the components for him newegg and was wondering what you guys think of? And should he just use xp or go vista business 32bit?
GIGABYTE GA-MA790X-UD4P = motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
The tower is Rosewill Conqueror RPS-01-WB500P which comes with a 500W power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147118
CPU is gonna be AMD athlon 64X2 5600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103685
Video card HIS Hightech H467QT512P Radeon HD 4670
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161252
LG Black 22X DVD+R
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136144
And the hard drive would prob be a 250GB prob get seagate
RAM 4GB DDR2 800MHZ ram since running that cpu
Wanna know if everything will be working smooth and everything is compatible.. If anyone have any suggestions about any of these i will appreciate it!
I think it looks like a porcupine got shoved in a PCI slot. I would stick with the D-link as they make lots of wireless networking components so i would expect they would have higher quality wireless cards. As n is backwards compatible with g i dont know if its worth the price premium to upgrade to a card that suports n.
I have never worked with the wireless network cards myself as i would rather just run another line of ethernet cable through the house so im not sure if the difference between the best and worst cards are noticeable i just know that the broadcom chip in my laptop has a ton of issues but i doubt there are any issue free wireless cards.
Looks good, scrap the rosewill case though. I would never recommend a PSU from rosewill. I would go with say a 500W from Corsair, I know it will cost some more, but you will almost never have to worry about it. The PSU is one of the most important parts. With 4GB stay 32-bit, Vista Bussiness would be fine, doesn't soud like they need Bussiness though. HD 4670 is good, everything looks OK.
just added a few more things to the build and took out a couple
changed the mobo -ASUS M4A78 Plus AM3/AM2+/AM2
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131381
Tower -XION Dazl XON-503 Black with Blue LED
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208025
Power supply- OCZ 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
will this make work and be better than my first picks when coming to power supply? and will the cpu up top work with the motherboard?
That OCZ PSU will work fine. Nice efficentcy on that.
Now for the Mobo and the Vid card. If Sims 2 is really the most demanding thing they do, I'd say drop the vid card and buy a 790GX mobo. On board graphics will be more than enough for HTPC apps and Sims 2. It has HDMI out on the mobo itself.
If you're not OC, get this combo and you get a much better CPU also for $160 free s/h. If you are going to OC, then take a look at an Asus or Gigabyte board instead.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.213837
You can still get the 4670, but for what they are using the system for, really isn't going to be used. So I'd say save the money now, and then if they do need a more powerful GPU later (because of change in use of the PC) then it's ready to add instead of getting rid of the 4670.
wait i would put this card instead of the one above
HIS H465FS512P Radeon HD 4650
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161262
and was wondering if you could connect this to a tv in hdmi. If i connect with dvi to hdmi connector. instead of using vga would that be better in graphics wise.. He told me he uses sony bravia 32inch as his screen dont know why i guess for sng.. prob uses wireless mouse and keyboard.
I was actually going to suggest that, but as it seemed a budget build, didn't think the DDR3 was what you were looking for. The onboard graphics will be more than enough for the Sims and TV. No need for a vid card for their current usage.
So yes, that combo would be my first choice with this ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231200
If you need something a little cheaper, this isn't the greatest, but can be downclocked to perform better:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227316
If you think the extra $20 is worth it and since you won't be needing any video card, get the mobo with the X3 710. The extra core will help later on down the road and get more life out of the system.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.212278
my last and final question is/favor is..
if you guys can find a good wirless card to add on a cheap one preferably and
since they have an hp you guys think i can take the hard drive and cd/dvd drive from the computer if im able to get it out and has the same connections from the psu?
save more money.. and tahnks alot hunter skora you guys helped me alot! :)
Depends how old the HP is, their hard drives and optical drives are easy to get out, i have done that a bunch, but if they are IDE drives you are going to need to position them very close together in the case as the ASUS IDE cable that comes with their motherboards doesnt have much slack between the two connectors.
If they are sata you are golden, HP unlike Dell uses stock parts which makes life easier, just remember you likely have to pop off the front panel and pull the optical drive out, and some of their hard drive cages swing out of the case, screwed me up for a while when i had to change the HDD in my old HP.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127080
There are cheaper ones but i would go for the d-link, especially if the router you are using is also a D-link router. I would expect the d-link one to be a bit more reliable than a rosewill or something, but keep in mind that gaming over wireless isnt the best plan, has the nasty habit of dropping out at the worst possible time. But if you really just want a cheap one there is an ASUS one for $11.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833320022
If its that recent then they are sata and it will be super easy.
If you are not overclocking, the stock fan is fine. If you are then, lite overclocking is still fine with the stock fan, but any target more than 3.0 ghz I'd find an aftermarket cooler. But expect to spend more than just $10. I'll see if I can't find a good example later, but I'm OTD now. Good luck,
Skora
