Building a computer for GIS friend. Need storage advice?
noobtastic88
23
Hi all
I am building a computer for a GIS friend.
I know what I need for RAM, cpu, etc, requirements but I am a bit stuck on what to get him for storage
Was thinking a RAID 1 pair of SSDs for boot drive and another pair of RAID 1 SATA 2 TB drives for data. But I am a bit concerned about read/write speeds with his GIS work and I dont want those hard drives to be the bottleneck.
Wondering if it is a better approach to buy some 600 GB 10k SAS drives and put all 4 of them in RAID 5 to get me up to the storage requirement amount. Mind you I only have 4 drive slots to work with and that would create one big physical volume
Anyone have some suggestions on which approach would be better? Thanks much
I don't recommend RAID1 for boot drive. The extra complexity isn't justified by any extra security. Drive failure is a low probability. There are too many other ways that your OS drive can get messed up that RAID doesn't protect. Get good backup software, and create a restore image.
This system sounds like a commercial use system. Backup strategies are important if you use the HW to make money. You have to ensure client data is protected for long term.
From my experience with GIS software, they love fast storage, so I would suggest something like a 250GB SSD for a boot disk, another 250GB SSD (ideally m.2) as the work space and then 2 2TB disks in RAID 1 for the final data output and storage of past projects etc. This way you get as fast a system for GIS as possible.
I also agree with Kanewolf, you want to make sure that the data is being backed up as well
I think the best solution is to put 2 SSDs in RAID 0 OR gat an M.2 SSD (Recommended)
and get another 2 large storage hard disks and put them in RAID 1
(Preferably WD [Black for the extra reliabilty] OR [Blue to save the extra money])
