Hi, I would like a little advice on how to proceed with building my new system - https://pcpartpicker.com/user/andy_werber/saved/#view=tQBmD3
1. I have one of those old computer bays in my desk. (click to see picture) There's about 1.5 inches on both sides of the case, and 3.5 inches above. The case only has ventilation from the front, back and top. I also have a room air conditioner for my room. I would really like to put the computer in this bay, that way the computer is completely out of my way. Please share your opinions on this.
2. I now have the case, power supply, keyboard & mouse and motherboard. Can I go ahead and put these together and test to see that the motherboard works? A long time ago, I had a problem putting a system together because I did not screw in the motherboard properly. The rest of the parts will be here by Wednesday. Should I just wait? If I do wait, what's the minimal build that will allow me to test to make sure the bios boots up?
3. I've never installed case fans. Are there any problems I should be aware of? Are there any really dumb things I could do (I'm good at those)?
4. Do you happen to know of any videos worth watching? I found one simple one. But it did not show case fans or inserting an m2 device (I've never installed one of those before, looks simple enough). I also found one that looked really good with regard to the components I will use, but the guy kept talking and talking. I want to avoid those.
5. Are anti-static gloves really necessary if I ground myself properly?
Thanks for any help with these questions,
Andy
Andy
