Build Advice Building a viable system with a budget of 500 USD
Dec 16, 2024
My desktop gave away after almost 15 years. It had a good run.
Now, Im planning to get a good enough PC that its able to play most of the games of the older generation of hardware and less required newer ones.
Games like Skyrim SE (with Mods), Crusader Kings 3, Football Manager, League of Legends, Dark Souls series, GTA V and prior ones from the 2000's era.
What would you guys recommend?
500 dollars for all parts.
Do you insist on new parts as well as "viable"?
How far are you willing to lower your expectations?
Motherboard, RAM, CPU, power supply, drive for sure.
Possibly plus case, cooler if not included with CPU, video card if you cannot make do with whatever graphics may be included with the CPU, case fans, operating system.
My two thoughts:
1; do nothing until you can spend more than 500
2; severely lower your expectations.
You can probably cobble something together if you need only motherboard, RAM, CPU, power supply, and a drive. Five pieces. For all I know, the integrated graphics on a semi-modern CPU can do a tolerable job on those games you mentioned.
Of course, you might stumble over something on your local used market. Ebay or whatever is available.
boxed 5600 with cooler + second-handed b450, 125$
6600xt, 145$
8gx2 d4 mem, 30$
relieable 1t tlc ssd, 60$
box of your shoes as a case, 0$
reliable 650w psu, 70$
remaining 70$, raise the price of items mentioned according to your region. It's the price in my region.
