Question Building advice
Atonon
9
Hi, i need some advice on how to upgrade my PC.
I am not english, so sorry for my writing mistakes
thx in advance!
Parts to Upgrade: CPU, mobo, RAM and M.2 with 1TB(or better technology if it exists)
Do you need to buy OS: No
Preferred Website(s) for Parts: not preferred any
Location: I am writing from europe, i need to know the better parts and then i will try to find the best store for my location
Parts Preferences: I don't mind AMD or Intel, just in case one of these is best for my RTX 3080 i will choose that one
Overclocking: No, i only will do Overclocking if it can be done by softwae
SLI or Crossfire: I think not, i only have one RTX 3080 and won't buy another one
Your Monitor Resolution: 2K and another one 1080p
Additional Comments: i can expend about 1000 -1200 dollars, but i could increase a bit if it's worth the money.
And Most Importantly, Why Are You Upgrading: I want to recycle my PC for gaming and working, i usually work with 2-3 virtual machines at a time
You don't mention needing a CPU heatsink/cooler, so I assume you already have one.
What is it? It may limit your choice of suitable CPUs.
Hi!
Thx for help!
My current cooler is: Enermax Liqmax II 120S
I have been looking for a possible configuration but don't know if it has any issue or incompatibility, here it is:
* Intel i5-13400
* Asus Tuf gaming Z690 PLUS
* Samsung 990 PRO 1TB
* G.Skill Trident Z5 RGB DDR5 6400 Mhz 32GB
I think i don't need a M2 disipator, but not sure if i would have to buy one for this CPU
thx in advance!
What country are you located?
Reactions: Atonon
i5 DDR4
PCPartPicker Part List
CPU: *Intel Core i5-13400F 2.5 GHz 10-Core Processor (€203.38 @ LIFE Informatica)
CPU Cooler: *Deepcool AK400 66.47 CFM CPU Cooler (€37.50 @ Coolmod)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard (€147.90 @ PC Componentes)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (€72.99 @ Corsair)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (€144.80 @ Neobyte)
Total: €606.57
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-05-04 00:07 CEST+0200
Reactions: Atonon
i5 DDR5
Motherboard: *Gigabyte B760 GAMING X ATX LGA1700 Motherboard (€160.50 @ Amazon Espana)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory (€132.80 @ Amazon Espana)
Total: €678.98
Generated by PCPartPicker 2023-05-04 00:11 CEST+0200
Reactions: Atonon
i7 DDR5
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor (€369.50 @ Coolmod)
CPU Cooler: *Deepcool AK620 68.99 CFM CPU Cooler (€58.87 @ LIFE Informatica)
Motherboard: *Gigabyte B760 AORUS ELITE AX ATX LGA1700 Motherboard (€203.96 @ LIFE Informatica)
Total: €909.93
Generated by PCPartPicker 2023-05-04 00:16 CEST+0200
Reactions: Atonon
i7 DDR4
Total: €794.06
Generated by PCPartPicker 2023-05-04 00:18 CEST+0200
Reactions: Atonon
AM5 option:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (€493.80 @ Neobyte)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler (€45.90 @ Amazon Espana)
Motherboard: ASRock B650E PG RIPTIDE WIFI ATX AM5 Motherboard (€268.50 @ Coolmod)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory (€114.99 @ Amazon Espana)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (€144.80 @ Neobyte)
Total: €1067.99
Generated by PCPartPicker 2023-05-04 08:05 CEST+0200
Reactions: Atonon
Just noticed that you are also working with virtual machines. If you want more cores between your VMs, just get the 7950X cpu with 16 cores.
The 13900 has 8 hyperthreaded performance cores and 16 single threaded efficiency cores.
Splitting them with VMs will put the win 11 thread scheduler into a frenzy, maybe...
Reactions: Atonon
* Intel i5-13400
That can work; I like the 13400.
One possibility to verify is that the initial Z690 motherboards did not have 13th gen support.
The enabling bios was released way back in June 2022 so any new stock should be fine.
I do not see any ability to update the bios without a cpu.
I think I might pick a motherboard with a 700 series chipset.
Since the 13400 can not be overclocked(nor would you want to even with a z processor) consider a B760 based motherboard.
Your current aio cooler will need a lga1700 adapter kit.
13400 will come with a suitable cooler that you might want to try first.
It is not an overly hot chip.
Since aio coolers do not last forever, I would buy a simple air cooler if you wanted to upgrade cooling.
Trident Z is excellent ram. But, you are paying more for the RGB "bling" and unnecessary fancy heat spreaders.
Reactions: Atonon
i7 DDR4
Total: €794.06
I think i will go for this, changing the 2x16GB vs 2x32GB and also changing the Samsung 970 Evo Plus 2 vs Samsung 990 pro 1TB SSD PCIe 4.0 NVMeM.2
Reactions: Why_Me
