[SOLVED] Building first gaming pc, not sure about some things.
Dec 23, 2018
I have recently been trying to get into some games which are more demanding than my current laptop can handle. I don't know a whole lot about the technical side of things, for example if everything is going to be compatible with everything else, or what case to get, etc.
The parts I intend to purchase are as follows:
Corsair VS Series 350 Watt Power Supply
SAPPHIRE Radeon RX570 PULSE ITX 4GB GDDR5 DP/HDMI/DVI-D Graphics Card.
ARCTIC Freezer 33 eSports ONE with 120 mm PWM Processor
Team T-Force Vulcan 2 x 4GB DDR4 3000MHz 1.35v 288-pin
Ryzen 5 2600 CPU
MSI B450M PRO-M2 Motherboard, Socket AM4, B450, DDR4, S-ATA 600, Micro ATX
Intel SSD 545s Series 2.5" 256GB SATA III Solid State Drive
I also have a HDMI monitor, USB keyboard, USB microphone, USB mouse, and headset in mind but they are more generic so I feel as though they are less necessary to mention specifically.
This all brings me to about 600-700 GBP. I am not sure if all parts are going to be compatible (or a good idea to use, for example is one part considerably out of place) with eachother, what case to get, and if there is anything else (other than a HDMI cable) I am going to need. Don't assume I know the obvious, either.
One final note is that I do intend on overclocking some time in the future and I have tried to choose parts which reflect that, but again, I am not certain.
If you're planning on OC'ing the CPU and/or the GPU, 500W would be the minimum, yes. Always look for a strong +12v rail when buying a PSU. Good names are Seasonic, Evga, XFX, Corsair to name a few. You'll probably need to spend at least $50+ to get a good enough one for OC'ing. This Seasonic is...
So if I use a 500W PSU everything should work well? Also how do I choose a PSU? There's loads of different brands and I'm not sure which to go with.
If you're planning on OC'ing the CPU and/or the GPU, 500W would be the minimum, yes. Always look for a strong +12v rail when buying a PSU. Good names are Seasonic, Evga, XFX, Corsair to name a few. You'll probably need to spend at least $50+ to get a good enough one for OC'ing. This Seasonic is a low cost, solid performer.
