Building my 1200 dollar pc HELP
Draco the White 7
7
This is my build http://pcpartpicker.com/p/8JZsQ7.
Will my motherboard be able to support my 16gb of Ram? And is it the right motherboard? I've been debating between the one I have or the MSI gaming 5 and the ASUS one I have? Reliability is a must as well and will the MSI gaming 5 be able to handle my 16gb of ram? Any additions are welcomed I want to be able to stream very well Anne able to play Breaking point,day Z,LOL,multiplayer shooters and RPG and the MSI Z97 Gaming 7 MBO how is that is it worth it? To go that over asus? Please help want this build to be my first build where it goes well and doesn't break down on me thankyou.
Well i would go with the msi it is the most reliable motherboard i had infact i still use it now not as single issue and it support to 32gb
http://pcpartpicker.com/p/dQPfLk
This have better ram for editing and stuff and the msi mobo for 1200.40 all budget thanks
If this helped you select best answer please
Yes the Asus Z97-A ATX LGA1150 Motherboard supports up to 32GB of ram. Asus is extremely reliable and this is a great motherboard that you have picked out. If you need reliability for sure go with this motherboard
The msi i guess because it have awesom onboard sound pluss its millitary classified xD something like that plus its 10 dollar cheaper and SR 71 black bird putted his 2 cents on the msi i think not sure though
