Building my first gaming pc, i just need some advice on if my build will work
A few points to now:
1. On the H170 chipset, and a locked CPU - your RAM will be limited to 2133MHz speeds. No sense buying faster.
2. The 600B from EVGA is far from the best, and there are much better options.
For the pricepoint, I'd be inclined to look to an AMD option if I were you.
If the budget can be stretched a little, I feel the 8GB 580 is a worthwhile investment over the 3GB 1060.
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor (£166.74 @ Aria PC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard (£63.93 @ Ebuyer)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory (£111.59 @ Aria PC)...
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.99 @ Aria PC)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card (£234.92 @ Amazon UK)
Case: Cooler Master - MasterBox 5 (White) ATX Mid Tower Case (£49.98 @ Amazon UK)
Power Supply: Rosewill - Capstone 650W 80+ Gold Certified Semi-Modular ATX Power Supply (£75.99 @ Amazon UK)
Total: £741.14
Generated by PCPartPicker 2017-06-12 18:06 BST+0100
No reason to go for 6500, when 7500 is cheaper. Changed mobo and ram to fit 7500, GPU and PSU as well.
CPU: Intel - Core i5-7500 3.4GHz Quad-Core Processor (£172.50 @ Aria PC)
Motherboard: Gigabyte - GA-H270-Gaming 3 ATX LGA1151 Motherboard (£99.60 @ Aria PC)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory (£63.18 @ CCL Computers)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£41.88 @ Aria PC)
Video Card: MSI - Radeon RX 580 4GB ARMOR OC Video Card (£214.99 @ Amazon UK)
Case: NZXT - S340 (White) ATX Mid Tower Case (£61.32 @ Aria PC)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply (£48.36 @ Ebuyer)
Total: £701.83
Generated by PCPartPicker 2017-06-12 18:14 BST+0100
I'd go for Ryzen at that budget, you could easily get a 1500x or you could squeeze in a 1600. You would want to get faster RAM for ryzen, as it effects performance significantly. And for 100 dollars, you could get an atx b350 mobo. An ssd is also useful, just get the cheapest 120gb that comes from a decent brand. A semi modular PSU is better for cable management and keeps the build clean.
I'm not an expert pc builder and I have only just ordered my parts for my first build so what I have just said might just be rubbish, so bear that in mind.
https://uk.pcpartpicker.com/list/x4pKD8
Guys , you're not going to get a 580 in the UK for at least 4 weeks, likely longer.
Ryzen 1500x+1060 6gb , exact same price as the original build.
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard (£86.80 @ Alza)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory (£67.56 @ Aria PC)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card (£235.09 @ More Computers)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply (£47.93 @ Ebuyer)
Total: £707.32
Generated by PCPartPicker 2017-06-13 15:22 BST+0100
Here is the list:
Motherboard: Gigabyte - GA-B250M-D2V Micro ATX LGA1151 Motherboard (£55.53 @ Ebuyer)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory (£50.99 @ Aria PC)
Video Card: MSI - GeForce GTX 1070 8GB Video Card (£323.64 @ Amazon UK)
Case: Fractal Design - Core 2300 ATX Mid Tower Case (£44.23 @ Amazon UK)
Total: £732.81
Generated by PCPartPicker 2017-06-13 15:34 BST+0100
A very strong combo of Intel i5-7500 and NVIDIA GTX1070 is great for gaming.
