Building my first PC (Help with Components)
AshLMX
11
Hello there! So this will be my first time building a computer and i am wondering if all of the following components will work correctly and if they're all compatible with each other in order for me to successfully build it.
Asus GeForce GTX 770 Graphics Card:
http://amzn.to/1e9WdtG
Gigabyte Z87-HD3 Motherboard:
http://amzn.to/1h64LQc
Intel Core i5 4670K Quad Core CPU:
http://amzn.to/1bKAc1h
Fractal Design Define R4 PC Case:
http://amzn.to/1jWnqjH
Corsair Builder Series 750W PSU:
http://amzn.to/1b1RfHH
For the next parts i plan to use some old components from my old PC to save a bit of money.
I plan on using a 2TB Hard Drive (SATA Disk Drive)
I plan on using 2 4GB DDR3 RAM Sticks
and my old Optical Disk
So, can anyone tell me if there is anything i should know or if i need to change any of these components because they do not fit/match up, etc. Thanks.
