Building my first PC (need help/advice)
JaspherIan
9
Motherboard : MSI H97M-E35
Processor : Core i5-4690K
Graphics card : Zotac GTX 970 4GB
RAM : G.Skill Ripjaws 8GB
Storage : Seagate 1TB SSHD
Power Supply : FSP Raider 750W 80 Silver
Case : Raidmax Super Altas
+ optical drive & cpu fan
My budget is around $1000
(Monitor and other periphs not included yet)
Are all parts compatible?
Will it work without the gpu?
Do I need a sound card or does my motherboard already have it?
Will my psu handle it or do I need a better one?
Am I missing anything?
samuspunk
95
12
All parts are compatible, it can work with the i5 integrated graphics if you remove the GTX 970, the motherboard has an integrated sound card, a good quality 550W PSU is enough for that build, and finally, no, you´re not missing anything.
Hope I helped you and ask if you have more questions.
Similar threads
