Building my first PC, will all of these things work together?
Datwomey
13
Hey, building my first gaming PC here, I've got a good amount of research done, and I'd like to know if all of these will work together in the case as I'm planning on buying it tomorrow if I can at all, specs listed below.
Case - Corsair 300R
RAM - Corsair Low Profile (2x4GB)
SSD - Samsung 840 EVO 250GB
CPU - Intel i5 4670K
HDD - WD 1TB
Motherboard - MSI Z87-G45-GAMING ATX Motherboard
OS - Windows 7 Home Premium 64 Bit
GPU - Nvidia GeForce GTX 760
Power Supply - Corsair 600W
DVD Drive - Samsung 24x SATA
I have purchased a Wi-Fi Card as well, but it didn't need to be specified.
Also, I will be gaming on a 42" television which runs at 50/60FPS, would that be okay for running with this build?
I'll mostly be playing games like BF4, Titanfall, PayDay etc.
If anyone has any suggested improvements they'd be much obliged, as long as it didn't go over my budget of around £830.
I'd also like to keep my SSD at 250GB as many people suggest lowering it, and will be over clocking, just not instantly, hence why I'm going for the 4670K over the standard 4670:)
As a result of not over clocking right now, I will be using the stock CPU cooler, will that be adequate?
Will not be doing anything strenuous like recording or editing.
The television is a Toshiba Regza 42HL833B, will that be able to run games at High/ Ultra settings with these specs?
And, it says it runs 50/60Hz, could anyone explain if that's 50 or 60 FPS?
Finally, I would like to buy everything off of Amazon UK if at all possible.
Thanks a lot.
