[SOLVED] Building my first PC
Dec 24, 2021
6
Hello guys!
I am about to build my first pc and I was wondering if these parts are all compatible and are good for 3D rendering and applications like Nuke, Maya, Houdini etc...
Please let me know if I could change some parts !
PC PARTMODELPRICE
CASECorsair iCUE 220T RGB Airflow€100.00
MOTHERBOARDMPG Z590 GAMING FORCE
CPU + MOTHERBOARDCore i9-11900F + MSI MPG Z590 GAMING CARBON WIFI€832.00
GPUASUS GeForce RTX 3080 10 GB GDDR6X Pci-E 3 x DisplayPorts / 2 x HDMI€1,316.00
RAMCorsair Vengeance LPX Black 16GB 3200 MHz AMD Ryzen€61.00
SSDIntegral 256GB SSD NVME M.2 2280€30.00
HARD DRIVESeagate BarraCuda, 1 TB, Hard Disk€43.00
COOLING SYSTEMCorsair iCUE H150i ELITE€178.00
PSUEVGA 600 W1, 80+ WHITE 600W€47.00
OS
Hi @jacob249358 thanks for the reply. I am currently in Italy but livig in London after christmas. I can both buy from Italy and London. The price for the CPU is added with the MOTHERBOARD. (https://www.ldlc.com/it-it/scheda/P...B_tFIBDVKX2ZNMFqvzIWiSnDXP4cRT4saAmssEALw_wcB)
What alternatives should I opt for?
I made a part list that is missing the GPU and case. I would get a 3080 for as cheap as you can find. And then the case is mostly preference so just pick one that is atx and then ask here or just look at reviews to make sure it has good airflow. here is the parts list.
https://uk.pcpartpicker.com/list/NB22K3
This is a better CPU than you...
Hello guys!
PC PARTMODELPRICE
OS
They are compatible but that CPU is not very good for the price. Also that is ryzen optimized ram with an intel CPU. And I think you need more than 16gb. Also let's get some more storage. That power supply is not going to be enough either. If you let me know your country I can put a parts list together for you
Reactions: claudngtt
This is a better CPU than you had, double the ram, more and faster storage, good power supply, and the z690 platform so you can upgrade all the way to a 13900k whenever that comes out. Also, the cooler is more reliable and quieter. And the whole thing is cheaper. I tried to make it around the price of everything you had before but I can do less or more if you want. Also do you have keyboard, mouse, and monitor(s)?
Thanks for the help @jacob249358 !!
Since I am fairly new I thought that having an i9 would be better (?), apparently not!😂
If you don’t mind explaining me why this would be better?
I wanted to spend around 2,200£, the components that you chose will fit the budget more or less! Thanks again!
If you are gaming, the 3080 is about as good as it gets. Good pick there.
But, on a new top end build, I would go with 12th gen. I5/i7/i9 will make very little difference in gaming.
What you get is more threads which are good for batch multithreaded processing. Games depend more on single thread performance.
I5-12600K is a great gaming processor.
Here is a review:
https://www.guru3d.com/articles_pages/core_i5_12600k_processor_review,21.html
Today, I would pick the DDR4 motherboard and ram.
DDR5 components are more expensive and do not perform any better.
@jacob249358 @DSzymborski
So this would be the updated build...
Only one SSD without any HD will work, you reckon?
PC PARTMODELPRICETOT
CASECorsair iCUE 4000X RGB ATX Mid Tower Case ( https://www.amazon.co.uk/Corsair-Tempered-Mid-Tower-RapidRoute-Management/dp/B08C76W2WM )£61.00£2,416.00
MOTHERBOARDGigabyte Z690 UD DDR4 ATX LGA1700 Motherboard£190.00
CPUIntel Core i7-12700K 3.6 GHz 12-Core Processor£380.00
GPUASUS GeForce RTX 3080 10 GB GDDR6X Pci-E 3 x DisplayPorts / 2 x HDMI£1,300.00
RAMCorsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory£115.00
SSDSamsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive£200.00
COOLING SYSTEM Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler£90.00
PSUCorsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply£80.00
OS
https://www.zoro.co.uk/shop/compute...-6-displayport-hdmi-2-7-slot-rgb/p/ZT1693836S
I also found this RTX but I don't understand what is the difference between all the 3080s 😵
Is still the TUF Gaming so for the money worth it.
Would personally get this cooler,
https://uk.pcpartpicker.com/product...-ii-280-728-cfm-liquid-cpu-cooler-acfre00066a
wouldn't worry too much about the con above which is that it might leak.
Would personally asos get a seperate ssd for Windows. If you would have to reinstall would all the data on the other disk just stay.
Already looked at this thread and had something similar in the pcpartpicker build, Can look at ssd's i chose, maybe case which is a better version to me for the better airflow but no rgb,
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor (£284.75 @ Infinite Computing)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler (£81.15 @ Amazon UK)
Motherboard: Gigabyte Z690 UD DDR4 ATX LGA1700 Motherboard (£190.98 @ Novatech)
Memory: Corsair Vengeance RGB RT 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (£129.11 @ Amazon UK)
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive (£67.98 @ Amazon UK)
Storage: ADATA XPG SX8200 Pro 2 TB M.2-2280 NVME Solid State Drive (£173.47 @ Ebuyer)
Video Card: Palit GeForce RTX 3080 10 GB GamingPro Video Card (£1149.99 @ Technextday)
Case: Corsair 4000D Airflow ATX Mid Tower Case (£59.98 @ Currys PC World Business)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£108.99 @ AWD-IT)
Case Fan: ARCTIC P12 PST CO 56.3 CFM 120 mm Fan (£6.89 @ Alza)
Total: £2253.29
Generated by PCPartPicker 2021-12-27 11:31 GMT+0000
different RTX 3080 as well, also a cheaper one and available right now.
Used the 12600K which is already as good as the 11900K in that first build, but if you would want the 12700K and can spare that money also good.
About those ssd's, you get 500gb more M.2 storage for 40 pounds extra.
The NH-D15 is a great cooler btw. Just rate the Arctic just a tad higher myself.
OS
Perfect, I would change nothing.
RE: the different 3080 cards, the chips all come from the same source, namely Nvidia.
The better binned chips will be used in slightly faster models that sell for more. You mostly get what you pay for.
@Vic 40 @Phaaze88 @jacob249358
Thanks everyone, I think I sorted everything out now. This is the final build put together with your advices. I think that the rapport between quality and price is fair.
PC PARTMODELPRICELINKSTOT
CASECorsair 4000D Airflow ATX Mid-Tower£59.99CASE£2,193.98
MOTHERBOARDGigabyte Z690 UD DDR4 ATX LGA1700 Motherboard£170.00MOTHERBOARD
CPUIntel Core i7-12700K 3.6 GHz 12-Core Processor£371.00CPU
GPUASUS GeForce RTX 3080 10 GB GDDR6X Pci-E 3 x DisplayPorts / 2 x HDMI£1,149.99GPU
RAMCorsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory£110.00RAM
SSDSamsung 970 EVO Plus 500 GB (TO INSTALL OS)£50.00SSD for OS
HARD DRIVEAdata XPG SX8200 Pro 1TB M.2-2280 PCIe 3.0 x4 NVMe£100.00STORAGE
COOLING SYSTEM Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler£93.00COOLING SYSTEM
PSUCorsair RM850x W 80+ Gold Certified Fully Modular ATX Power Supply£90.00PSU
OS
Looks good.
I would use a single 2tb m.2 ssd for all.
The cost would likely be the same.
The benefit is easier space management with just one large address space.
You have a good budget, go for the very best:
Samsung 980 pro is as good as it gets and seems to be fairly priced:
You can compare devices on the anandtech bench app:
https://www.anandtech.com/bench/product/2760?vs=2793
Both options together in that list i made are as expensive together as that one drive.
The Adata XPG SX8200 Pro in that list was about the best and cheapest M.2 2tb drive on offer and is a really good one.
Build looks nice btw. Just myself would chose the higher amount of storage and go for the 2tb version, but maybe that gets you above budget and you have a third slot left if you wanted to add more in time. Would also add a fan like i did, put the back fan to the front so the two Corsair fans are there and add the bought one in the back, not alot of money in that.
