Building My First Pc
kjoman
19
Hey guys, I am new to this website, But i have been reading and it looks like you guys help out a lot!
Ive been wanting to build a new PC for pure gaming and a little work on the side no biggie. I have a laptop and its just not working out for me. I need a PC!
I have been looking at MSY for parts but to be honest i have no idea what im doing. Could you guys help me with what to buy and explain the parts to me?
I have a budget of around $1000 but if i can spend less i would be happy. I have no Monitor but have keyboard and mouse, headphones etc.
Thank you for your time
http://pccasegear.com/
I have time to configure a pc for you now. Ok here it goes...
EVGA GeForce GTX 560 Ti 1GB
http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1193&products_id=16868 -$269
Western Digital Caviar Blue 1TB WD10EALX
http://www.pccasegear.com/index.php?main_page=product_info&cPath=210_344&products_id=15933 -$65
G.Skill Ripjaws X F3-10666CL9D-8GBXL (2x4GB) DDR3
http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_912&products_id=16509 -$55
ASUS VE228H 21.5in Widescreen LED Monitor
http://www.pccasegear.com/index.php?main_page=product_info&cPath=558_1212&products_id=16052 -$165
Corsair TX-650 V2 Power Supply...
Hi there! I'm guessing your from Australia since your buying from MSY. May i suggest www.PcCaseGear.com ? Their site is so easy to navigate and they have a better range of parts.
What size monitor are you planning on getting? I would suggest a 23 inch.
I will write down a build for you later when i wake up.
CoolerMaster Storm Enforcer In stock $99.00 $99.00
ASUS GeForce GTX 560Ti DirectCU II TOP 1GB In stock $289.00 $289.00
Western Digital Caviar Black 1TB WD1002FAEX In stock $89.00 $89.00
DDR3 In stock $55.00 $55.00
ASUS P8Z68-V LE Motherboard In stock $159.00 $159.00
LG GH22NS70 22x SATA DVD-RW Drive OEM In stock $25.00 $25.00
CoolerMaster Silent Pro M700 700W In stock $129.00 $129.00
Overclocking is the process of running your CPU (or other components) at a higher clock speed than comes standard by the manufacturer. Used to be tough, now it's a pretty painless process thanks to manufacturers making it easy and a shload of guides on the web.
The reason folks want to know whether or not you plan to overclock is because that choice will impact your overall build. Overclocking generates more heat, and that heat must be effectively channeled by better heat sinks, case design, etc.
Grats on choosing to build your first PC. As long as you keep yourself well informed it's a fun and generally painless process that rewards the user in the long run with. Have fun with it!
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_535&products_id=17211 -$113
ASRock 970 Extreme4 Motherboard
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18040 -$115
Samsung SH-222AB SATA DVDRW Drive
http://www.pccasegear.com/index.php?main_page=product_info&products_id=17348 -$22
Sharkoon T9 Value Red Case USB 3.0
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18014 -$69
AMD Phenom II X4 965 Black Edition
http://www.pccasegear.com/index.php?main_page=product_info&products_id=12293 -$135
Total = $1008 AUD
Hope it helps!
hey i noticed that there was no cpu put in? What one would i best be looking at, i know that the motherboard has to be able to support it to.
Haha sent this after you had put a post up my bad!
Yeah i was tierd when i did it. Look at my previous post. Looks like what you need at the price you want (dont forget to best answer me if i helped you 😀 ).
Good luck!
Hehehe, no it won't work. JOKES! Yeah sure, its just a bit more expensive. I'm currently in the making of building my dream PC, im just waiting for the new AMD bulldozer proccesors and graphics cards to come out. Im speding about $3000 on my build, but it will last me forever and i need everything like the headset, mouse, keyboard and monitor.
P.S. if you can i would wait for AMD's Bulldozer to come out because it is likley to drop other CPU prices and you might even get a better CPU for the same price range.
Good luck and feel free to ask any questions.
