Hi. I'm upgrading from an i3 4150 with a new mobo, cpu, ram and gpu
I7 9700k 8x 3.6ghz
Msi z390-a pro
msi GTX 1660
2x 8gb corsair ram 3200
New atx mid tower
with older components
Antec 450w psu 3yrs old
2x ssds 120gb + 240gb 6yrs / 4yrs old
Mouse/keyboard 1yr old each
I have been advised to upgrade my PSU which I will do, but I'd like to know for sure my issue will be resolved.
My problem is the pc boots into bios, everything is detected ie cpu ram fans mobo plugs temps ssds etc.
However, I can't load an OS. Original w7 on 120 ssd won't pass the startup screen and safe mode crashes right after the driver loading list with some graphic tearing at the top. Turning off xhci for the usb in bios allows me to turn numlock on and off during this safe mode freeze.
Win10 install usb freezes before loading. Advanced Repair options crash after loading files. Ununtu live 18.04 didn't work I intend to try the later release also.
Basically, with minimum to all hardware installed in the case results in the same type of crash. I was able to boot into safe mode before a reset to default settings following a change with ram sticks. Now it always crashes in this way. Desperate for advice. Will a new, gold rated psu solve this?
I've reseated everything including the cpu to no avail.
I7 9700k 8x 3.6ghz
Msi z390-a pro
msi GTX 1660
New atx mid tower
