Question Built a New PC with some previous parts - Games Can’t Run - Ryzen 5 5600x + RX 6700 XT - please help
Aug 25, 2024
22
Hello! I just built a new pc and my games aren’t running as smoothly as they should be (from looking at benchmarks with the same components) . I actually returned my graphics card because I thought I had a faulty graphics card and installed a new one and I’m having the same issues and games won’t even load in.
- Ryzen 5 5600x
- Gigabyte B450 DS3H mobo (F63c bios)
- RX 6700 XT
- 16 GB 3200 DDR4
- 500 MB Wd blue sata SSD
- 2 TB M.2 Wd black
-EVGA 600 watt 80+ bronze power supply
These are the current specs, I originally had a RX 6600 but since it wasn’t performing well I returned and upgraded but I’m having the same problems. Everything is brand new except the motherboard and sata ssd and power supply. The computer works but games don’t run or even load in now. When they do load in the performance is bad. I reinstalled my graphics card drivers as my old SSD had a rtx 3070. Im not sure what to do as I thought my graphics card was the problem, but it turns out it’s not…is there a chance my CPU is faulty, as two different graphics cards aren’t working?
I reinstalled the graphics drivers and I think I uninstalled the old Nvidia drivers using DDU in safe mode.
you think you did, or you did?
if you're unsure, make sure that you do.
EVGA 600 watt
include the actual make & model.
RX 6700 XT
had a rtx 3070
the RTX 3070 is near to the RX 6700 in terms of performance.
were you getting better performance before,
and have you tried the RTX 3070 again to see if it also suffers from the same current issue(s)?
EVGA 600 BR, 80+ Bronze 600W,​
Is there any way to check if all of my Nvidia drivers are uninstalled? I followed a tutorial to uninstall them. The problem is I sold my old pc 2 years ago, but kept the power supply ssd and motherboard. they were kind of just sitting in my closet until i wanted to make a new pc. I sold the rtx 3070 a while ago so I cannot test it.
- Ryzen 5 5600x
- RX 6700 XT
- 16 GB 3200 DDR4
- 2 TB M.2 Wd black
Did you do a clean Windows install or was there an OS installed on that SSD already? You will be chasing problems until you do a clean Windows install, IMO.
OS was already installed. I’m actually doing a clean windows install right as we speak.
just by running DDU again and making sure to remove all graphics data.
but you definitely need a fresh OS install with a new motherboard.
hopefully that helps with any real issue you're facing.
and don't trust videos touting performance claims.
even if you do have the exact same hardware with the exact same settings, you have to keep in mind that these videos are there to draw in views, so what they're claiming can always just be some bs to draw in another click.
EVGA 600 BR
and yes, this is a lower quality unit, not really intended for heavy gaming systems.
so I should get a new motherboard and power supply?
Reinstall the game(s). DDU doesn't remove the Nvidia shader compiler settings saved in the game files.
I reinstalled the games 3 different times. After doing a clean install of windows and drivers I can launch the games however the performance is still terrible. I’ve noticed that the cpu utilization is at 100% whilst the GPU utilization is bouncing anywhere from 0%-100% and not staying steady at all. It also looks like my cou is running at 4.5 clock speed when it’s base is around 3.7.
On an AMD system, make sure you have the latest MB/chipset drivers from AMD.
The ones from the motherboard manufacturer aren't always up to date and they can make a noticeable difference.
Are the motherboard drivers different from bios or the same thing?
They are different - you can get them directly from AMD's web site
The AMD auto detect utility will get the best ones for your motherboard.
If your CPU is showing 100 percent, you should probably see what you get in a CPU benchmark like cinebench.
A 5600X shouldn't be running at 100 percent on a 6700XT unless you are running at 720P low to avoid the GPU bottleneck.
Reactions: BaneRyan
Actually I do have the chipset drivers then I installed them. I’ll definitely do the CPU benchmark. I think my cpu may be the problem. I return my new rx 6600 because it wasn’t running well and now the rx 6700xt isn’t either. Is it possible I have a faulty cpu?
I was playing in 1080p ultra btw
Should I try to resit my cpu, apply new thermal paste, or reinstall the heat sink? Screwing in the heat sink was giving me some problems. I was thinking what if the heat sink wasn’t touching the cpu or something. But honestly not sure I don’t really know much.
It is unlikely but possible for you to have a bad CPU.
The 5600X is generally pretty reliable and a bad CPU normally causes crashes
A poorly seated CPU cooler will cause thermal throttling.
You should run a monitoring utility like HWINFO64 or when you run your test.
If it shows that your CPU is running hot, I'd definitely repaste and reinstall the heatsink
A 5600X is a 65 watt part and it doesn't generally get that hot unless you use PBO/OC.
If you haven't reset the motherboard to optimized defaults, you may want to see if that provides stable behavior.
Reactions: BaneRyan
I was running MSI Afterburn and it was not going above 80 degrees Celsius. I’m currently updating the bios to the lates settings.
Would the cinebench show if I have a bad cpu?
I just ran the cinebench 2024 multi core test and it got 538 points, is that normal?
I haven't seen a lot of R24 scores for a 5600x.
The ones I have seen are between 640 and 700, but they are probably overclocking or doing a PBO undervolt,
Even a score of 538 should be adequate for 1080P high on a 6700.
If you can do a 30 minute Cinebench run and your aren't exceeding 80 degrees, your CPU, cooler and paste are probably fine.
You might want to try a GPU test like Furmark
I get 12000 points (200FPS) with a 6700XT and 5800X in the 1080P benchmark
You should get something similar.
You might want to try a different PCIe slot for the video card.
The X4 slot should be slower than the X16 slot, but if it works better in the X4 slot, you may have a MB issue.
Reactions: BaneRyan
Doing the FurMark test now. Thank you for all your help! I'm definitely going to try the other slot in my graphics card after this.
Benchmarks in games with the same specs as mine are getting almost double as mine. This is incredibly frustrating.
Score is 9860 points (164 fps) Max temp 68 degrees Celsius max usage 99% max clock 2121 mhz and min 10 mhz
