Built a PC. Missing Base System Device drivers
I3reeze
70
Hey all,
I built a PC a while ago and recently found that a lot of my drivers cannot be found.
Under "Other devices" I'm missing:
52 Base System Device drivers
1 PCI Device
5 Performance Counters
1 SM Bus Controller
1 System Interrupt Controller
Under "System devices" I'm missing:
1 High Definition Audio Bus
Here's my build:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor (Purchased For $388.13)
CPU Cooler: Corsair H110i GT 113.0 CFM Liquid CPU Cooler (Purchased For $129.99)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard (Purchased For $232.89)
Memory: G.Skill Ripjaws Series 16GB (4 x 4GB) DDR4-2400 Memory (Purchased For $210.98)
Storage: Transcend MTS600 512GB M.2-2260 Solid State Drive (Purchased For $223.99)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive (Purchased For $66.68)
Video Card: Sapphire Radeon R9 290X 8GB Vapor-X Video Card (2-Way CrossFire) (Purchased For $482.90)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case (Purchased For $109.99)
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply (Purchased For $205.35)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer (Purchased For $21.00)
Case Fan: Noctua NF-A14 industrialPPC-2000 107.4 CFM 140mm Fan (Purchased For $26.45)
Monitor: Asus PB278Q 60Hz 27.0" Monitor (Purchased For $440.00)
Other: Code Keyboard (Purchased For $169.88)
Other: Windows 8.1 64 Bit (Purchased For $15.00)
I see a lot of other posts talking about a specific PC or a prebuilt, but very few if any talking about a built machine.
Thanks for the help.
^^^^ Yes if you aren't connected to the internet, you will need another PC to get the files needed to get your Mobo drivers.
Yes, thank you all. I was unaware that it was only motherboard drivers I should be looking at. I thought I had to troubleshoot to figure out which drivers are the issue.
