While installing two new HDDs I had to switch around some SATA power cables so everything would fit properly in my Corsair 570X. While moving the cables around I switched which SATA power cable the fan controller was plugged into. I turned the PC on (started up with all components powering up) and immediately smoke started coming from the side of the case where the fan controller is attached. I unplugged the power and discovered the cable that runs from the fan controller to the SATA power cable had melted, but there was no damage to the SATA cable itself or the connection. It should also be noted that I've had this case for almost two years now without any major issues like this.
I haven't powered on the machine since the melting in fear of further damaging something. What caused the fan controller wire to melt? Why did the PSU not detect the short (if that is what happened) and shut itself off?
The computer has a RM100x PSU which has also functioned for more than a year without a hitch.
