R Ray37 Honorable Nov 13, 2013 2 0 10,510 Nov 13, 2013 #1 Burning A video using Nero 9 >> I want to burn to DVD-R how do I do this
Solution lonewolf7 Nov 14, 2013 Its simple. 1. Start Nero Express. 2. Select Data DVD from menu. 3. Add files you want to burn. 3. Click next. 4. Click Burn. 5. You are done. Good luck.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,106 912 120,140 Nov 14, 2013 #2 Tutorial here (PDF document): http://support.gateway.com/s/SOFTWARE/misc/nero/7512812/manuals/HowtowriteDVD-VideotoDVD.pdf Upvote 0 Downvote
lonewolf7 Splendid May 6, 2013 5,111 2 24,965 Nov 14, 2013 Solution #3 Its simple. 1. Start Nero Express. 2. Select Data DVD from menu. 3. Add files you want to burn. 3. Click next. 4. Click Burn. 5. You are done. Good luck. Upvote 0 Downvote Solution
