Buying a better GPU but need help
okjak808
227
29
10,840
Hi guys i'm planing on buying a used GPU here is the link https://www.ebay.com/itm/Original-ASUS-GTX750-GTX-750-1GB-GDDR5-128Bit-GTX750-DF-1GD5-Video-Card/142646373060?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3Dcbde1e894e4a439bb9a0bcf2b3f18d55%26pid%3D100677%26rk%3D2%26rkt%3D30%26mehot%3Dlo%26sd%3D253456916379%26itm%3D142646373060&_trksid=p2385738.c100677.m4598#shpCntId i really wanna get it for my Emachine ET1831-05 i bought a new PSU 450 watts and much more the problem is will it be compatible with my software it says compatible with win 7 but will it work on win 10 and will it also fit cause it seems a little bit big its just that i cant find a low profile one because its expensive
The gpu will have no problem with windows 10, only remember to uninstall the old graphic drivers and install the new ones from Nvidia's site after you install it. As for if it'll fit, probably, you can measure the inside of the case and compare it with these ones for the gpu : 18.49 x 11.50 x3.58 Centimeter
Sorry guys I’m just not smart on math and I really hate it but here are the dimensions of my desktop Unit Dimensions:
14.2 x 7.1 x 16.2-inches (H x W x D, approximate)
Weight: 18 lbs.
I can’t seem to find the dimensions for the you am getting but making sure will it really fit? Because I don’t wanna buy and ending up not fitting and I would also have to wait for quite a while maybe like next month it will be a waste of time.
