I have decided to embark on building my first gaming PC and have just been researching the components.
I will be using the machine solely for gaming.
Having had a quick research I have come up with a set of components making a PC in my price range:
My question is; is the CPU over the top for my purpose? (as it has 8 cores and I am going to be using the PC for gaming)
The reason I am considering this CPU is that I am not sure my budget can stretch to the i7 and from what I can tell this CPU is better and cheaper than the i5s although I'm not sure (as I said this is my first build).
Would love for some advice as to whether this is a good CPU choice and if not what CPUs I should consider instead.
Thanks in advance.
CPU: AMD FX8350
Graphics: Nvidia GeForce GTX 960
Memory: 8GB
Thanks in advance.
