Hi everyone. I am buying these new parts for my pc and since I've already ordered them I am worried since I've done some researched and found out some information that I don't know whether is true or not. I would really appreciate some help and confirmation from everyone . So I have ordered the parts about and I'm reading things like "the hyper 212 isnt enough for an i7 7700k, when you turn xmp on in the bios to use the full ram mhz it overclocks the 7700k to 4.5ghz and will give you 85 degrees C which is bad, the MSI Z270 PRO CARBON automatically overvollts your processor which is bad and can cause it to overheat as well as having the xmp option on. I am really confused. I just want to know:
when I have windows power plan set on high performance.
what will the ghz of the processor go to and will it overheat
will it throttle at the temperature it will get to
does the msi z270 pro carbon make the processor get even hotter because of overvolting.
I really just need some confirmation about all of this and if these components are gonna actually work (I know they will fit but when I say work I mean not overheat or mess up)
Thank you so much for your help everyone.
