Buying parts for my new gaming rig RIGHT NOW! Need advice
LucasWolfrey
14
GIGABYTE GA-Z87X-UD3H LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Intel Core i5-4670K Haswell 3.4GHz
GeForce GTX 780 3GB 384-bit GDDR5 PCI Express 3.0 SLI Support
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2133
ADATA Premier Pro SP900 ASP900S3-256GM-C 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
AZZA Solano 1000 Black Japanese SECC Steel/Metal mesh in front MicroATX/ATX/Full ATX Computer Case
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
ASUS VG248QE Black 24" 144Hz 1ms (GTG) HDMI Widescreen
Total price is around $1900 with monitor
This is what I'm getting. My goal is to have a pc that will max everything for the next few years, and I plan on grabbing another 780 later down the road. My question to the pros: Is there anything you would add or change to this build? Please let me know. I'm buying parts today!
You don't need 16GB of RAM for gaming; drop it down to 8GB.
I would go with a different SSD, ADATA doesn't particularly make the fastest, nor the most reliable SSDs. Samsung Pro/Evo would do nicely.
If you plan on SLI-ing in the future, go with a HX850 or AX860 or higher. The 750 is below what is recommend, and it's wasted money if you'll need to upgrade it down the line.
