Buying parts next week and wanted to make sure this build looks good?
ibroughtmoresnacks
7
After lots of research I think I have come to my final choice for my first build ever. I wanted it to be able to play games 2014 and back and stay under $600 with taxes (I don't like rebates). I do want to be able to play Day Z and Arma III
This is the build http://pcpartpicker.com/p/JBT2Bm
I've seen a lot people recommend the G3258 as a good CPU and I have a Microcenter near me so I can take advantage of the bundle deal for $100. In June of next year i'm gonna upgrade to an i5. Don't know how to overclock, but I added a CPU cooler as I will research and learn what to do.
So does this look good?
Especially you will need the 212 cooler since no one will buy this Pentium not overclocking it. Expect squeezing 40% more performance out of that chip after overclocking.
For that budget, and with that combo deal, this is one of the few times I'd recommend a Pentium.
For literally $5 more, you can get the Antec 300, which is a superior case; I have used several and they are super easy to work with:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Can also pick that up refurbished directly from antec.com for $30 if you're comfortable with that.
I know you said you hate rebates, but here are two that are really, REALLY worth it ... Zalman 9900 CPU cooler for $25, it beats the dog crap out of the one on your list and even competes reasonably well with the high-end multi-fan big air coolers. Since you will want to overclock the hell out of that Pentium to get enough performance, the cooler is going to be important; you will want a good one. This has been known to reduce temperatures 10-15C immediately.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118046
Also, a much, much better power supply for half the price:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=125449&CatId=5431
It has a rebate, but even before that it's the same price as the one you have selected. People here will tell you to avoid the Corsair CX/Builder series, and rightly so. It is their budget line and not made the same as other Corsair units - cheap components that are known to die on you. That XFX one is top of the line, and a steal at that price too.
What about this cooler Cooler Master Evo 212? I put the other one in my build to save costs. I've heard people recommend this one a lot. I would definitely get this one if its a good option.
For $5 more dollars i'll get the Antec 300 then. I appreciate your help!
