Jack_162 :
bitwright :
What do you mean by "some work with large files"? If this is mainly a gaming rig, then you might not really need hyperthreading and could save yourself $100 by switching to an i5 6500 instead.
Your choice of mobo seems fine. At least I didn't see any glaring negative reviews for it. And your choice of PSU seems fine too. Since you aren't overclocking 550W should be enough.
As for the video card, the GTX 1070 is superb for 1080p, but in my opinion isn't really "overkill" at that resolution. The GTX 1060 is the card most people are recommending for 1080p though, and it's much cheaper than the GTX 1070. But if you choose to go with a GTX 1070 and a 1080p monitor, I don't think that would be a waste of money. That's just my personal opinion though.
Forget the work thing. But you are the second person to suggest a 15 6500 instead. I really didnt know the difference before but after looking into it and since it is mainly going to be used for gaming i think i might switch to the i5 6500. How do you feel about the current monitor choice 27" 1440p 144hz? Too big?
Nah, that monitor is a great value monitor, very good quality, and will futureproof you if you decide to go 1070 SLI.
I would actually recommend picking up a 1080 to go with it, pushes more frames, and will allow you to get the most out of your monitor, maxing everything. Power supply can be changed out for something better value and equal quality, and the same case in a different color is $40 cheaper on newegg with some discounts etc.
Put this together for just over 2000, see part picker direct link for discounts.
PCPartPicker part list:
http://pcpartpicker.com/list/dnYf9W
Price breakdown by merchant: http://pcpartpicker.com/list/dnYf9W/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($204.99 @ Newegg)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($35.00)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard ($77.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($67.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($90.13 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($69.99 @ Newegg)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply ($78.99 @ SuperBiiz)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer ($46.85 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Monitor: Dell S2716DG 27.0" 144Hz Monitor ($537.00 @ Adorama)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($31.48 @ B&H)
Other: Gigabyte GeForce GTX 1080 8GB G1 Gaming Video Card ($649.00)
Total: $2010.78
Generated by PCPartPicker 2016-07-28 19:44 EDT-0400
