[SOLVED] Buying Used Parts
Apr 1, 2019
9
Hello, I'm 14 and can't get a job. So I resorted to buying used parts online to save some money. I haven't actually bought any parts yet and I'm probably only going to buy the GPU used. I'm scared though, what if the part doesn't work? What should I look out for?
https://offerup.com/item/detail/647698242/ (The Part in question)
do you guys think $125 is a good price for the MSI 1050 ti
No. A few new RX 570s for $120-$130 and there's even an 8 GB 570 at $140. I wouldn't be interested in spending the same amount of money on a used 1050 Ti as it takes to buy a new, faster card.
The only exception would be if I had a very basic power supply that I absolutely could not change.
I wouldn't even consider a used 1050 Ti until we get to $100. And even at $100, I think I'd probably still prefer a new 570.
let's begin with your budget, what should it be? Used parts may not work but are you still wiling to do it?
i cannot access the account apparently they have blocked the country i am in...
i guess you have to tell me what you're looking for then.
Best tip would be to buy it on a platform that has protections for buyers. This platform does not, it explicitly says all sales are final. On eBay, you actually have some recourse if you buy a defective item.
$140 is also a pretty craptacular price for a used 1050 Ti, considering you can find new ones under $170 now and RX 570s can be found new for under $140 and are faster than a 1050 Ti. I wouldn't advise touching a used 1050 Ti unless we're talking $100 or so and even less if it's on a platform with no protections for buyers.
I don't have a set budget, In fact, I have already bought every part except the GPU and the CPU. Also, I have 125$ saved, and I'm using that money to buy the CPU on Amazon.
The guy I'm buying it from has agreed to test it before I buy it. He said he will put it in his old build while I'm present.
I have haggled the guy down to $125. Also, we've agreed to test the part on his old build.
Seller's Page so you can see it.
As was suggested, at least if you have a 450+ watt power supply for your system, I would rather go for a brand new Radeon RX 570 for about the same price...
https://pcpartpicker.com/products/video-card/overall-list/#c=392&sort=price&page=1
An RX 570 should provide nearly 50% more graphics performance, and of course a new one will come with a fresh warranty, so you are not stuck without a card if it happens to fail within the first couple years.
Reactions: TJ Hooker
Here in the Philippines i saw these used GPU
Zotac GTX980Ti 6GB GDDR5 Founder's Edition for Php9000=$176
Palit GTX1070 JetStream used for 6 months mining -Php9000=$176
MSI Radeon RX 580 Gaming 8Gb for -Php6000 =$117
NVIdia GALax GTX 1060 6gb 192bit exoc Black from 2nd owner -Php6500=$127
Gigabyte Windforce R9 380 Blue Led 4gb 256bit ddr5 -Php 3500=$68
Gigabyte Radeon R9 380x -Php4500=$88
