R realchaos Distinguished Jan 30, 2013 5,287 0 19,960 Feb 19, 2013 #1 This is my first build and I often hear this buzzing noise like bzzzzzzzzzzz. If i use my hand to push the the front part of the computer from the top, it stops. Anyone knows whats the cause of it and how to fix it?
johnpaul182 Distinguished May 17, 2011 210 0 18,690 Feb 19, 2013 #2 Your disk drive could be a little loose, try re-installing it. Upvote 0 Downvote
R realchaos Distinguished Jan 30, 2013 5,287 0 19,960 Feb 19, 2013 #3 Just re-plugging the cables? Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 19, 2013 #4 The HDD or DVD drive could be loose. The case could be rattly if its cheap. Upvote 0 Downvote
johnpaul182 Distinguished May 17, 2011 210 0 18,690 Feb 19, 2013 #5 No, what i mean is your disk drive might be rattling a little, try making sure it is firmly secured! Upvote 0 Downvote
R realchaos Distinguished Jan 30, 2013 5,287 0 19,960 Feb 19, 2013 #6 I have the rosewill challenger case. Let me make sure the dvd drive is secure Upvote 0 Downvote
smorizio Titan Jan 22, 2010 30,980 11 125,315 Feb 19, 2013 #7 if there a front fan it may be loose or they over tightened the fan and it rubbing.. Upvote 0 Downvote
