[SOLVED] C49RG90 Left Side Flashes Red Cuts out
Sep 8, 2020
Hello all,
I have recently purchased a new C49RG90 and have it connected to a Dell XPS 17 (RTX 2060 Max Q GPU, i7 8 core CPU, 32GB ram) via a WD19TB dock and connected with DP 1.4. When I was playing Flight Simulator 2020 I found the left half of the display would flash red several times as per the attached picture and then the whole screen would black out for a couple seconds and then return to normal. Has anyone else experienced this? Is this a display defect? A displayport cable malfunction? Or is this a result of the GPU? I noticed that it also seems to happen when browsing Chrome.
Image here:
View: https://imgur.com/OMYKXxX
So is the monitor connected straight to the 2060?
Latest posts
