Cabinet Fan size
Volcruz
Commendable
Apr 22, 2016
65
Hey there
I have one 120 mm fan installed in my cabinet on the back side and i have holes for 2 more fans on the left side of the case but the screw spacing is some what odd and i can't figure out the fan size i need
10cm*8cm (screw space)
And 120 mm fan dosen't fit
The only other thing I can think of would be a water cooling radiator but they tend to mount the same as 120mm fans.
The strange thing is the 100x 80 spacing,as obviously fans are circular .
I wonder if it is designed for some sort of ducting.
So have you tried a 120mm fan to see if the holes line up to the 100mm x 100mm spacing.
This of course would only allow you to fit one fan.
If they don't line up then it looks like they are designed for some non standard fans as the next standard fan size below 120mm is 92mm which has a mounting spacing of 82.5 mm.
