cabinet help ????
lolred
my hardware config
cabinet : Circle cc512
Processor: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
Motherboard: Intel dh61ww
Graphic cards:ASUS R7260X-DC2OC-2GD5
Hard Disk : Seagate ST2000DL003-9VT166 ATA Device (2000GB)
Hard Disk : TOSHIBA DT01ACA300 ATA Device (3001GB)
Power supply : Corsair CX500
i replaced the default fan of processor with Cool master Hyper 212X
after the installation of new fan my processor is working in good temp but the heat sink of the new cooler is larger than my cpu i cant close the cabinet and have to keep it open also my cabinets both fan are not able to keep my system cool enough as after use of 3 to 4 hrs all my system is quite hot.i though fist about replacing fan but considering the cabinet has no space to install one i would like any suggestion on which cabinet would be best suited to run my above hardware the max i can spare for a cabinet is $100.
You can look at NZXT Phantom 410 its a mid tower case with 1x 200 mm and 2 x 120 mm fans pre installed and a mini fan controller with low med and high fan settings looks good and has good cable management.
http://mdcomputers.in/products/cabinet/nzxt-cabinet-phantom-410-white.html&filter=MANUFFUNAM=NZXT=38=MANUFACTURER
