Cable manage... help me fix this problem!!
Ryan0710
258
Hey all,
I’m re routing and wiring all my PCs cables and I’m not very good at it. I langed to get them all through the back side of my pc (back side panel) and wore them through various holes and on to the motherboard, fans, etc. with zip ties. After all that, my panel won’t fit back on! I’ve tried pushing the cables forward, but not exactly sure how to escalate the situation. What should I do that won’t require re doing everything?? Lol, Thanks! -Ryan
(I’d add a picture, but I don’t know how) thanks again!
Nothing you can do aside from make sure the cables are not sticking out too far. No way to help you really without being there and seeing what you did.
