cable on 24pin connector is broken
magnus3142
68
Hello, i have a trouble with boards main connector, 1 wire is loose. When i turn on pc i cant enter bios or boot windows. Also thing is i dont know from which pin this loose wire came from. Is there anything i can do about it or am i hopeless?
Orange usually means a 3.3V line. If there's no empty well on the cable side, then it was tied to another cable to a single pin (Check pins 1, 2, & 13). Either way, if you can't boot the PC you should replace the PSU, there could be other wires broken in the connector. Hopefully this hasn't damaged the mobo.
Omg my bad, i could start pc now and its working, it was OC failure i had before it shut down.
But still where this wire comes from? Could anyone tell me? Pc working fine atm and hopefully it will.
trying to find a decent image of its 24 pin connecter on the net--cant quite find one thats clear enough yet
could also try emailing cooler master and asking them
or if you have a pc store locally that sells one could get a look at it there
Yes i can see that it came from 13th pin. There was 2 wires, 1 thick still inside and this thin one is loose. in manual thick one is +3.3V and thin one +3.3Vs
Im not sure what u just said, i checked that diagram u sent but it says about brown wire in pin 13 and doesnt say anything about double wires in pin 1,2,12. So does it mean that this wire came from pin 13 just has orange color instead of brown?
well finally i have found that this wire is from 13pin its a sense wire that should be tied to one of 3.3V wires, in my case its from pin 13. Well now left somehow to tie them back together which is not that easy. Any suggestion?
Would be best if i could take pin out of connector and then tighten them together, but i dont have a tool to take it out.
Easier way is just to cut thick wire from 13pin and then tied them together. but im not sure of this thin sense wire should be right inside the pin or its okay if i tied it about 1-2cm from/above the pin??
What would u do in my case? (i wont buy new psu because of 1 wire)
