I'd like to build a new assembled workstation. At first I checked various HP. DELL, Lenovo, Fujitsu and so on BUT their prices are completely unaffordable for what I'd like.
My fear is to assemble a wrong machine or too much expensive respect to the job I have to do. Considering that unfortunately there is no way to see a workstation like this working in order to try it with my own files I hope that people here form the forum help me in order to find the best cost affordable configuration.
CONSTRAINTS TO KEEP IN MIND
a) My maximum budget should not go over to 2000€ before taxes (here in Italy now 22% and skyrocketing to 25% very soon);
b) I live in Italy so I can't buy from Newegg.com !!! Parts needs to be available in this country which is very far (mentally) from US, UK; Germany or Netherlands markets. Normally Italy is one of the last countries where big international companies arrive to sell !
c) I am not a geek (not yet) so probably I will ask to somebody else to assemble the Workstation according to the final configuration I will select according to your suggestions.
d) Be patient, if I say stupid or wrong things because I am a beginner !!
e) I am afraid that the assembled Workstation is too noisy (fan at maximum speed even for small performances), highly energy consuming and maybe faulty (because of a wrong components selection or assemblage).
f) I'd like to reutilize my graphic board a Nvidia Quadro K2000
SOFTWARE I USE
a) Autocad Map 3D with Raster Design (now v. 2011) => files range between 20-120Mb. I mostly use 2D, I overlap a lot of raster. I use many big map blocks.
b) Carlson Mining for Autocad (v. 2011) => several tools for layers operations, cleaning, DTM construction, contour line generation, etc.. It works 2D (for calculation) and 3D (for visualization).
c) ESRI ArcDesktop (v. 10.2) => I use many raster layers of aerial picture with frequent refresh and redraw.
d) CAE Mining Studio [http://www.dataminesoftware.com/software/] for data management, 3D surface and stratigraphic modelling with a lot of wireframe calculation and 3D visualization
e) Photoshop CS6 => image editing and modification or correction. High resolution scan images used which range 70-150Mb in jpeg format (600*600dpi)
f) CoreDraw => layout preparation with files about 70-150Mb
g) AVS video converter => (to transform video format, 1-2GB)
After that I propose my configuration. Any suggestion or criticism is welcome. As I said I am not an expert. So I am here to learn and to enjoy your experience as user or as Workstation builders.
PCPartPicker part list: http://it.pcpartpicker.com/p/9GhRhM
Price breakdown by merchant: http://it.pcpartpicker.com/p/9GhRhM/by_merchant/
CPU: Intel Xeon E5-1630 V3 3.7GHz Quad-Core OEM/Tray Processor
CPU Cooler: Arctic Cooling ACFZI30 74.0 CFM Fluid Dynamic Bearing CPU Cooler
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard
Memory: Crucial 32GB (4 x 8GB) DDR4-2133 Memory
Storage: Samsung 850 Pro Series 512GB 2.5" Solid State Drive
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive (€149.10 @ Amazon Italia)
Case: Corsair 500R Black ATX Mid Tower Case
Power Supply: SeaSonic 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Generated by PCPartPicker 2015-03-17 21:11 CET+0100
SOFTWARE I USE
