[SOLVED] CAM stopped showing my CPU temperature + Liquid temp higher than usual
c1bas3k
35
Hey everyone,
so about 3 days ago I noticed that CAM software suddenly stopped showing my CPU temperature and CPU Fan Speed. I didn't really pay much attention to it, just figured the software might have f*cked up during launch or something...
But yesterday, CAM showed me a notification that the liquid temperature is too high. I checked CAM and indeed it was at 52°C which it usually isn't. Usually it sits around 42°C under heavy load. I was playing Civ VI when that happened and CPU load was at like 20ish % so nothing serious.
I am using i7-6700K OCed to 4,6 GHz cooled by Kraken X61. I would like to know if this issue happened to someone else as well or if you guys could help me with this. I googled that these temp are ok, but I am used to something else entirely, so I am better asking... thanks in advance.
You might have an outdated version of cam so I recommend uninstalling and installing the newer version on NZXTs website. 50c underlaid for water temp is fine as long as cpu temps are fine
