Hey Guys
I have just finished building my PC with a custom watercooling loop, using a Swiftech MCP655-PWM pump. It is connected to an ASUS maximus viii hero motherboard in the W_pump header.
The pump is working great and i am able to read the rpm in AI Suite 3.
My problem is that i am not able to control the rpm of the pump and it is currently running at full load (4830 rpm).
When i try to change the rpm in AI Suite 3, the curve changes but nothing happens to the pump. This is when the curve is adjusted in "smart mode", i can´t change it to "RPM Fix mode" for some reason?
I have been using the auto fan tuning and all my fans are working correctly and are adjustable.
Hope you guys have an answer, i didn't build a water-cooled PC for it to be noisy
