Can a Corsair H110 fit in NZXT Phantom 410 case?
albojr
6
So I'm wondering if the corsair h110 will fit in my nzxt phantom 410 case. I have read that it does and it doesn't. The h110 is a 280mm rad and is 29mm in thickness. the phantom 410 can support 2 140mm fans on top and has a clearance of 30mm. I dont know what to do. on paper it looks like its going to fit but im not for sure maybe someone with more experience can help me out.
I'm trying to see if the H110 fits, not the H100 or H100i. hehe the names are all so similar.
Lol oh o.k. my bad.
I'm in the same boat OP.
I have an H110 that I won, and love the smaller size of the 410 so I'm really hoping it fits. You are correct that it should fit judging by the specs, unlike the Kraken X60 that requires drilling the case for 15mm spacing instead of the 20mm spacing that Corsair used on the H110.
I ordered the White 410 yesterday, so I'll let you know if it fits when it gets here. If it doesn't work out I'll be returning the case for it's bigger brother.
Here is a thread where you can see that the top doesn't fit with a 240mm radiator that is 6cm tall, and the H110 is only 2.9cm tall.
*edited to add link
My package arrived today, and I'm happy to report that I was able to get the H110 fitted in the Phantom 410 mid tower case.
Be warned though, as it did not fit without a slight case mod. I had to open up 4 of the pre-drilled fan mounting holes due to how Corsair spaced the fans. Also the radiator touches the can conroller PCB, so I had to insulate it with layers of electrical tape. Last I had to remove one of the clips holding in the black mesh from the top for clearance, not that you can tell.
All in all it was pretty easy to get it to fit!
Hi I've just tried to fit the H110 into my 410, I've had the same problem as you where the holes don't allign up with the radiator due to the spacing. What do you mean by "open up" 4 of the mounting holes? Did you drill the holes?
I have the fans at the top and the radiator at the bottom set up as intake as the instructions recommended.
Thanks
Although Corsair says to set it up this way, I didn't have the clearance inside because of my motherboard. Instead I installed the radiator outside the case and the fans inside. NZXT designed it to be this way anyways.
When I said "open up" i meant I used a dremel tool to turn the existing holes into slots, allowing the bolts to pass through.
I know this thread is about the 410 but I was wondering if it would fit into the Phantom, it is unclear and on paper I think it will, just. If anyone happens to know or know of a thread that helps, please let me know.
I also have the same PC case and need to upgrade cooler. I am also in question of whether it will fit in the 410, so I wondered if you had pictures as you said you mounted it outside? Thanks in advance.
