Can a Corsair H115i Pro cooler fit with a Corsair 350D and ASUS Strix Z370G Motherboard?
AustinDavert
Commendable
Sep 20, 2016
Hi everyone,
I was wondering if anyone had any success with installing a 280mm radiator in the Corsair 350D on the top of the case? I wondered if there would be any clearance issues with the ASUS ROG Strix Z370G motherboard? I know that may be a bit difficult to answer, but I thought I would just ask!
Thanks so much!
-Austin
Yes yes it can. It can be a very tight fit and requires that you do not use the top 5.25" expansion bay, but honestly the bottom one is a pain to work with. Basically you have to install the radiator before the motherboard you might be able to do it after but I would be nervous.
