Can a Geforce GT620 (PCI-E x16 2.0) work with a x8 motherboard?
DanGFX
Commendable
Jul 30, 2016
I have a little question. I have an Dell Poweredge SC430 and i want to put there an Palit Geforce GT 620 2GB (PCI-E 2.0 x16) will it work on x8 1.0? (If not i can buy another graphics card...)
In theory the gt620 should work with pciex8, even the pciex4, because the pcie is backward compatible. But that dell has the intel e7230 chipset, it is old, I don't have time now, you may go to dell support to see there is any newer version BIOS. If the dell does support the newer BIOS like after 2009 or 2010 version, you should be fine, because the MB usually needs the BIOS to recognize the new hardware.
