Question Can a Gtx 1070 ti cooler fit on a rtx 2080 ti
Dec 20, 2018
17
i am thinking of upgrading my inno3d ichill x4 gtx 1070 ti to a zotac twin fan rtx 2080 ti. As the title says, can i take the 1070 ti and put it on the 2080 ti?
I doubt it, if you saw the 2080 you would quickly realize it is a 3 slot card and the heat sink on it is massive (twice the thickness of a standard 10xx series card
is it possible ? once you strip everything off the card ad are down to the bar cpu and mounting holes, if your lucky the holes will line up but I have serious doubts.
and even if it did I doubt that the heat sink of a 1080 is sufficient to manage the heat dispersal of a 2080 card.
Latest posts
