The HTPC keeps freezing, rebooting and BSD'ing. So I replaced it with a whole new computer. This one was doing the same thing, so I figured it might be the power in my room, so I got a UPS with AVR (auto voltage regulator) and put the HTPC and TV on it (and nothing else). That didn't work. So I thought it might be the USB network device, so I replaced it. Still happened. The only other thing left from the first computer is the keyboard. Out went the wireless keyboard and I put in my USB remote mouse. (no keyboard). Still happened. The ONLY thing that the new computer and the old computer have in common at this point is the monitor.
Have you ever heard of a monitor (plugged in via HDMI) causing problems that caused a PC to freeze, reboot or BSD?
I can not fathom what else could be the problem. All that is left is software. They both use W7, but so do my other computers. The old HTPC and the new HTPC use different AV/Malware software. (Eset and SAS vs AVG and Malwarebytes) The old used Firefox, the new uses Chrome. I am forced to use silverlight for Netflix, but after that they don't use any of the same software, plus everything else works fine on either the laptop or the desktop.
Does anyone have any ideas as to what the problem might be?
Also, the new case has better heat dissipation and I used low power/low heat components in the new HTPC, so it's running at about 35°C as opposed to the old HTPC which ran at about 45°C.
I use the HTPC for streaming Netflix almost exclusively, so there's very little CPU load.
