Question Can anyone help about latency (LatencyMon))
Aug 4, 2021
18
Idk why but i ahve latency problem, I might be sounding like a brat only 500 when others get like 10000 dpc latency, but the problem I'm wondering why I'm even getting 500 when I heard 200 is normal and im post optimizations getting 500... when I see what could be doing it, drivers tab is all good same with cpus tab so very confused.
Here, someone please check this out cause I don't know whats making it go to 500.
_
CONCLUSION
_
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:00:14 (h🇲🇲ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP-9LQS4HA
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: B450M DS3H, Gigabyte Technology Co., Ltd.
CPU: AuthenticAMD AMD Ryzen 5 3600 6-Core Processor
Logical processors: 12
Processor groups: 1
RAM: 16328 MB total
_
CPU SPEED
_
Reported CPU speed: 3593 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
_
MEASURED INTERRUPT TO USER PROCESS LATENCIES
_
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 553.80
Average measured interrupt to process latency (µs): 6.055958
Highest measured interrupt to DPC latency (µs): 551.80
Average measured interrupt to DPC latency (µs): 4.076281
_
REPORTED ISRs
_
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 22.593933
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.003189
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.003417
ISR count (execution time <250 µs): 2020
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 90.586140
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0.005026
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.013723
DPC count (execution time <250 µs): 6381
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 0
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Number of processes hit: 0
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 0.549948
CPU 0 ISR highest execution time (µs): 22.593933
CPU 0 ISR total execution time (s): 0.005642
CPU 0 ISR count: 1713
CPU 0 DPC highest execution time (µs): 90.586140
CPU 0 DPC total execution time (s): 0.020877
CPU 0 DPC count: 5252
_
CPU 1 Interrupt cycle time (s): 0.031916
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 0.941831
CPU 1 DPC total execution time (s): 0.000020
CPU 1 DPC count: 29
_
CPU 2 Interrupt cycle time (s): 0.038787
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 32.703590
CPU 2 DPC total execution time (s): 0.000249
CPU 2 DPC count: 152
_
CPU 3 Interrupt cycle time (s): 0.037108
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 8.426385
CPU 3 DPC total execution time (s): 0.000046
CPU 3 DPC count: 41
_
CPU 4 Interrupt cycle time (s): 0.037772
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 14.397996
CPU 4 DPC total execution time (s): 0.000389
CPU 4 DPC count: 212
_
CPU 5 Interrupt cycle time (s): 0.036498
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 1.242416
CPU 5 DPC total execution time (s): 0.000043
CPU 5 DPC count: 58
_
CPU 6 Interrupt cycle time (s): 0.037815
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 12.945171
CPU 6 DPC total execution time (s): 0.000055
CPU 6 DPC count: 32
_
CPU 7 Interrupt cycle time (s): 0.031167
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 1.903702
CPU 7 DPC total execution time (s): 0.000027
CPU 7 DPC count: 33
_
CPU 8 Interrupt cycle time (s): 0.036760
CPU 8 ISR highest execution time (µs): 1.062065
CPU 8 ISR total execution time (s): 0.000096
CPU 8 ISR count: 261
CPU 8 DPC highest execution time (µs): 12.504314
CPU 8 DPC total execution time (s): 0.000276
CPU 8 DPC count: 183
_
CPU 9 Interrupt cycle time (s): 0.029177
CPU 9 ISR highest execution time (µs): 0.480935
CPU 9 ISR total execution time (s): 0.000004
CPU 9 ISR count: 11
CPU 9 DPC highest execution time (µs): 9.147787
CPU 9 DPC total execution time (s): 0.000136
CPU 9 DPC count: 79
_
CPU 10 Interrupt cycle time (s): 0.035895
CPU 10 ISR highest execution time (µs): 0.681325
CPU 10 ISR total execution time (s): 0.000014
CPU 10 ISR count: 27
CPU 10 DPC highest execution time (µs): 32.212636
CPU 10 DPC total execution time (s): 0.000804
CPU 10 DPC count: 256
_
CPU 11 Interrupt cycle time (s): 0.027411
CPU 11 ISR highest execution time (µs): 0.701364
CPU 11 ISR total execution time (s): 0.000004
CPU 11 ISR count: 8
CPU 11 DPC highest execution time (µs): 13.065405
CPU 11 DPC total execution time (s): 0.000208
CPU 11 DPC count: 54
_
Bob.B
Respectable
Feb 8, 2021
1,952
233
1,890
71
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
Processor groups: 1
RAM: 16328 MB total
_
CPU SPEED
_
_
_
_
REPORTED ISRs
_
_
REPORTED DPCs
_
_
_
_
PER CPU DATA
_
_
CPU 1 ISR count: 0
CPU 1 DPC count: 29
_
CPU 2 ISR count: 0
_
CPU 3 ISR count: 0
CPU 3 DPC count: 41
_
CPU 4 ISR count: 0
_
CPU 5 ISR count: 0
CPU 5 DPC count: 58
_
CPU 6 ISR count: 0
CPU 6 DPC count: 32
_
CPU 7 ISR count: 0
CPU 7 DPC count: 33
_
_
CPU 9 ISR count: 11
CPU 9 DPC count: 79
_
_
CPU 11 ISR count: 8
_
Other than this latmon thing what does not work to your liking?
Aug 4, 2021
18
Do you the latest chipset driver?
How hot is the cpu getting?
Play with the windows power plans/settings....test.
i think I'm on the latest chipset updated it a week ago same with bios, I tried balanced ryzen its same and cpu is around 84 c in aida but when gaming i think its 65~ c
