Question Can I connect 2 4 pin 120mm fans to motherboard's CPU fan connecter using splitter bellow?
danil16
17
Hi Guys,
Can I connect 2 of 4 pin 120mm fans to motherboard's CPU fan connector using splitter bellow?
link
Please let me know.
Thank you,
Ildar Rafikov
Make and model of the fans you're using in your build? Generally if the fans are your run-of-the0-mill spec fans, they shouldn't be a problem on your motherboard. Make and model of your motherboard?
Thank you for your help.
Motherboards is Asus P8P67. I am going to be connecting them to 4-pin CPU_FAN.
So far I stopped on two fans below:
fans
I am going to be using those fans for cooling CPU radiator. Let me know if you recommend other silent fans.
thank you!
Thank you all for your answers.
Could you please confirm if I can connect two of Artic P12 PWM PST in the link below? I already ordered them but want to check with you Guys
Link
Thank you again!
I hear you and from all reviews that I watched on YouTube, Noctua is slightly better than Artic.
That said I don't like brown color of Noctua.
The price difference of 2.7 x kind of made my final decision.
