Can i connect myBlack Altec Lansing 5 1 Speaker System ADA995 to my tv
bubu_43
4
i have Black Altec Lansing 5.1 Speaker System ADA995 ,i dont want to buy any more speacker .
how can i hook thses up to my denon av ?
Yes you can hook this up to your TV using stereo sound 2.1
on your denon av you will need to provide a model number or a picture of the connections on back. please also provide the connections on the ADA995
my denon is avr 3802
5 speakers with phono type plugs connect to the back of my sub which would normally connect to the back of my pc with 3 phono (black yellow green) phono type plugs
You'll need 3 of these (or simular): http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Connect the actual speakers to your sub as normal.
Connect 1of the y-cables rca jacks to the denon Front L & R speaker out. Connect the speakers Front mini jack to this, the one from the sub.
Connect another to Denon Rear L & R speaker out. Connect the Speakers Rear mini jack to this
Connect the last one to Denons Sub and center which should connect to the sub & center mini plug. Please note that we have no way to tell if the rca's for the sub are on correctly. start off at a low volume on both the tv and the speakers and see if center and sub are working correctly, If not the swap the two rca jacks on the back of the denon.
Hi thanks ,
Just ordered leads ,will let u know how get on
Fingers crossed
Sounds easy enough
Okay, sorry to bring up an old thread. Could someone please help me. Same speaker system, ADA995, which I am currently using with an adaptor for mono sound from my iPod. Want to now buy an AV receiver and hook it up to the speakers to use with my TV. If I bought something like the link below, how would I do this? Can I follow the above instructions and just cut the RCA cables? Do they work like that? And could someone please explain exactly what goes into what?
Thanks
http://www.amazon.co.uk/Denon-AVR-X500-AV-Surround-Receiver/dp/B00C7SZT2W/ref=sr_1_1?ie=UTF8&qid=1389134505&sr=8-1&keywords=av+receiver
